29 Dec 2008 at 21:14 #1 The Halk The Halk Soldato Joined 13 May 2003 Posts 11,865 Location Hamilton I've not looked at air cooling for years, since I'm on water. However I'll need a bolt through cooler for a socket 939 board (2 bolts) as the standard attachment is no longer there. Something cheap would be ideal.
29 Dec 2008 at 21:25 #2 jak731 jak731 Soldato Joined 17 Mar 2007 Posts 5,508 Location Plymouth search MM/auction sites for a replacement standard attachment?
29 Dec 2008 at 21:40 #3 matt100 matt100 Soldato Joined 31 Jul 2004 Posts 13,807 Location Surrey The Halk said: I've not looked at air cooling for years, since I'm on water. However I'll need a bolt through cooler for a socket 939 board (2 bolts) as the standard attachment is no longer there. Something cheap would be ideal. Click to expand... can't you get any old cooler and hotfoot it off to B&Q (not a competitior are they? ) and get some nuts and bolts to suit?
30 Dec 2008 at 16:05 #4 kitfit1 kitfit1 Soldato Joined 24 Feb 2003 Posts 4,282 Location Stourport-On-Severn If it's a DFI NF4, i may well have a spare floating around somewhere.
30 Dec 2008 at 16:28 #5 The Halk The Halk Soldato OP Joined 13 May 2003 Posts 11,865 Location Hamilton It's an Asus A8N32-Sli Deluxe. They may all be standard though.
