What GPU do I have?
31 Jan 2007
Hello,
I have just set up an oldish machine to test soem applications on and am using it to post this message now and I grabbed an old AGP graphics card from some spares and used that in this machine and I need to install the correct drivers for it but I ahve no idea what card it is as it does not say on it. CCleaner doesn;t show the manufacturer or model and neither does the "Display" tab in DX Diag.
Any ideas on how I can find out what card is in this machine so I can install the correct drivers for it.
Thanks
Regards,
Neil
I by some digging around think thats it's a GeForce MX 440 which is excellent for what it will be used for.
Rounddodger - How can you say something is PAP when you don't for 1 know what it is and also how can it be pap if it does the job I am using it for. I suggest you think before you speak/post.
Thanks guys for all your help
Thanks
Regards,
Neil
Lets face it if its coming up as unknown with everything then it's going to be pap innit! I wouldn't worry about it lol.
Do a search for "Driver guide toolkit" its a small application which will give you the hardware id, type that into google and it will tell you what the hardware is.
