core voltage info ?
27 Jan 2005
Letchworth Herts uk
Hi All i,m looking to overclock my E6600 CPU and want to know what the core voltage is for it , and what is the best level to take it up to ? :confused:
1.325v - 1.35v is stock.
Totally depends on how good your cooling is how much you can take it to. I've gone upto 1.4v with my E6400 and it's rock solid at 3.3ghz and runs cool. You can go upto about 1.5v I think with very good air cooling but no more...
Just check what your VID is with coretemp. Mine's 1.2375v, although mine ran 2.4GHz with 1.1000v fine and 3.0GHz with around 1.2500v.
Im pretty sure the voltage in CPU-z is actual/current voltage, hence why it varies, not the rated vid which is the voltage to run your chip on when you have no OC
Yeah, that's right 95thrifles. In old versions of CPU-Z it used to be way out and I always went by the much more believable figure given by Everest. With the newer versions of CPU-Z it reads the same as Everest.
ok well i,m sort of at a dead end , i set the fsb at 266 and that puts my memory at 666 , but i,m stuck on the RAM settings and voltage ,any help plz ....
p.s i,m starting off slowly and going to up the fsb each time , but want to get the memory sorted out ,which is lost me totally oh and i only have Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB)
well your RAM is rated for 800Mhz so should be fine to run at just that, leave the timings on auto - or if you are having issues you could slacken them off a bit, and set your DIMM/RAM voltage manually to the vendors recomended. You should be fine then
okay so 400 fsb and 800 mHz Ram would be okay , and what abour the core voltage leave it on auto at first ?
