- 7 Mar 2005
- LU7
.js? It works fine in a .css format unless I'm missing something?Is that available for Opera? In a .js format?
Sorry, sent you an emailI just wanted to see if you (or I) could update the CSS on userstyles, please with some of the stuff I've done in my post above (20th Dec) ?
Willhub, there is a way to get it to work in Opera, here.
If you post whats been added here (as in post the code [ code] etc...) i'll add it to the another version of the style and post it up on userstyles.....
I have a few changes in my personal version to, so i'll just post another style each time it changes in case anyone prefers a different version.
I'm actually working on another style for here right now (how i spotted your post so quickly), and it's going pretty well, as i can see a few ways to do things easier then last time round..... any case it'll be up on Userstyles when done...
Wasn't sure if any of you lot visit GD on a regular basis.Can't really miss it Marc!I just want there to be an updated consistant version; sure people can modify it to whatever they want, but it would be good to have a 'trunk' version that everyone can start from.
And since no-one mentioned that thread here I wasn't sure.![]()
When I saw this thread had been bumped I just thought it had been bumped to continue the thread. Then I saw Spie's thread in GD and wondered if this thread had been bumped due to his thread. If you get me.It was the reason for my bump a few posts up, so people only just hearing about it now can get onboard and feel welcome, even if they don't know a single line of code.![]()
You're free to do what you want with the code posted.... by all means if you want to take the existing work and play around with it or create another version, then do it... and post it on userstyles.... it's free to register...
When I saw this thread had been bumped I just thought it had been bumped to continue the thread. Then I saw Spie's thread in GD and wondered if this thread had been bumped due to his thread. If you get me.![]()
Have you tried http://forums.overclockers.co.uk/showpost.php?p=12230358&postcount=176 ? And http://forums.overclockers.co.uk/showpost.php?p=12425239&postcount=183, http://forums.overclockers.co.uk/showpost.php?p=12425239&postcount=185 and http://forums.overclockers.co.uk/showpost.php?p=12425239&postcount=186.still can't make it work in opera, I tried removing the bit and deleting the } on the bottom but it's still not working
thanks in advance
thanks in advance
Excellent.got it thank you so much
