Installing new Graphics Drivers under boot camp?
19 Oct 2005
Kernow
Hey there,
Just wanted to ask if it was possible(and a good idea) to update the nVidia graphics drivers on my Unibody 2.8?
Is there any ones i should go for if so?
Cheers!
Always better to update the drivers as you'll (generally) get better performance from bug fixes and general improvements added by the card manufacturers.
Go to the nVidia site, look for the model card you have and install away.
Don't forget to uninstall the ones you have via the Control Panel first though :)
Hey EVH!
Cheers! Good to hear, wanted to make sure as ATI have specific ones for boot camp and when i installed updates with xp installed i got a bsod.
I shall install some new ones now as the ones that apple have given are terrible!
