- 17 Oct 2007
snip
Hi Gummidge and welcome to the forums. First of all, make sure you read the FAQ so you don't get into trouble for doing something that is against the rules which you weren't aware off.
Moving onto your specification. The first specification includes a top of the line graphics card which will mean you will be able to run the majority of games on extremely good settings at the native resolution of the Samsung SM-2233BW Cream 22" Widescreen LCD Monitor. Since this specification includes a Nvidia Geforce GTX 260 Core 216, there wasn't enough money to get say for example a Intel Core 2 Quad Pro Q6600. However, since the majority of games that are out and also upcoming release will be mainly GPU limited and the fact that you will be gaming at a fairly high resolution anyway, you will be far better of getting a better graphics card as opposed to a slightly better CPU.
Having said that though, once you have overclocked the Intel Pentium Dual-Core E5200, gaming performance won't be that far off an similarly clocked Intel Q6600 providing that particular game doesn't take advantage of more than 2 cores which at the moment is very far and few between.
Just one little thing I will point out with regards to the graphics card. If the NVIDIA Geforce GTX 280 is still available which is currently selling for £229.99 which can be found here by the time you come to purchase your system, then go for the NVIDIA Geforce GTX 280. If they are all gone though, the NVIDIA Geforce GTX 260 that is already in the specification will be fine.
Specification 1:
This second specification is really for if you are into photo editing, encoding and are a heavy multitasker. It doesn't include such a powerful GPU, though the ATI Radeon 4850 is certainly not a walk over, but does include the Intel Q6600 which will help if your system will be mainly used for the things that are mentioned above.
Specification 2:
snip
Hi Alrik, the specification you have done looks absolutely fine. The only component I would think about changing is the CPU to the Intel Core 2 Quad Pro Q6600. As you can see here, the performance difference of a dual core clocked around 600MHz higher than a quad core is very small and in my opinion it doesn't warrant losing the extra two cores because of this.
There aren't a lot of games that take advantage of more than 2 cores as of yet. However, this is likely to change and if for example a game does come out later in the year where running a quad core CPU does significantly boost the performance then you are already one step ahead.
I have also included the Thermalright TRUE Black 120 CPU Cooler which is exactly the same to the standard Thermalright Ultra-120 Extreme CPU Cooler but it includes a extra set of fan clips which means you will be able to add an extra fan in the future and slightly better thermal paste.
