- 6 Dec 2002
- North East
open beta tomorrow, woop!(CBA to torrent it now)
Woo
Although think I read they're going to cap the number of copies downloaded
Now, bloated or not, Vista is necessity to all of us in IT world.
And by now we kind of like the aero and quick search in start button whether we are ready to admit it or just moan for the sake of it. However. It is also true, that if we got that quick search and DX10 in XP majority of us would never look back at Vista.
right guys do i go to vista or windows 7
i did vista through beta but tbh i just went back to xp after a while the layout did my head in but ive messed on with windows 7 in a virtual pc and like it so do i take the leap and go to 7 or back to vista ? (everything is backup so it really dosent bother me if i loose work etc)
WooAlthough think I read they're going to cap the number of copies downloaded
Can't say I've had any problems with win7 as of yet, everything is stable & i'm using it as my primary OS, it is all up to you really, if you feel comfortable to use BETA software.
i do what software you using all the usual office dreamweaver photoshop etc ???? just woundering will vista drivers work as my laptop can be a pain in the rear for drivers (generic always throws up problems thats all)
damn... i hope not! i dont wanna stay up late. mind you, i'll get it at work tomorrow morning i hope there are still some left.
80% of the way done now, but it is hellishly slow and keeps interrupting every 2 minutes. Normally I get in excess of 2000-3000kb speeds, but I'm getting 20-500 this morning.
huh? are you getting this from the official site as an official download? i dont get it. lol
i dunno if i can wait for tomorrow.
I don't use Dreamweaver, Photoshop, Office. But from the products I've used:
Google Chrome (no problems)
Winamp 5.541 (no problems)
Skype 3.8.0.115 (no problems)
Iphonebrowser (slight problem at the start, just needed to run in compatibility mode)
Last.fm (no problems)
Tightvnc (no problems)
Imgburn "newest" (no problems)
itunes 8.0 (no problems)
Virtual clone drive (no problems)
Utorrent 1.8.1 (no problems)
VLC "newest" (not a problem)
Avira Antivir (no problem)
mIRC "newest" (no problems)
Manycam 2.3 (no problems)
DUmeter 4.01 (no problems)
Winrar "newest" (no problems)
Flash/Divx/Java (no problems)
All I've used so far![]()
I've heard that Photoshop CS4 works on it, Office is definitely going to work no doubt about that, Not so sure about Dreamweaver.
Once i installed Win7 detected all my drivers apart from Soundcard & Webcam, But that was solved by going to Windows Update & it was there. If your laptop installs all drivers fine on Vista, then it should be ok for win7.
Note I'm using 32bit Win7, so not too sure about the 64bit build & how those programs/drivers work.
I'm getting it from MSDN from Microsoft. It appeared late last night, but I only started downloading this morning.
so emailiscrap do you get a key to activate it then mate cheers
MSDN gives you a key to activate, you should be able to use the MSDN version longer than 30 days once activated, dunno how long exactly though but there is a limit.
