Many thanks matey, works a treat now!
Grand stuff !
Bit of an annoying issue that raised its head on XP64 and Vista64......but at least its a simple fix
On other news: How are people finding it? Any compatibility options? Any noticeable performance change between Vista 64 and Windows 7 64?
So far, so good.................I'd be lying if I said general gaming performance has jumped from Vista64, but performance is similar or just slightly behind using the current Vista64 8.12 Catalysts with a lot of current and recent titles..
Did have one crash in Catalyst Control Centre while looking through colour adjustments, but haven't been able to repeat it so I'd let it slide..
Crysis series, Far Cry series, Tomb Raider series, COD4+5, Half-Life series, Left4Dead etc etc all work with no issues (although I'd make sure you have the latest DirectX Runtime installed)..
Outside of gaming, the OS is fairly robust with similar or better performance in many apps although there are a few programs and drivers (X-Fi for one) out there that either need a bit of help (compatibility mode) or plain don't install (Acronis TrueImage is the biggest casualty for me, although I hear Daemon Tools also doesn't install (but VirtualCloneDrive is fine)..
In good shape at this early stage, and certainly more stable than Vista was at its beta stage..
