Hi Sharpy, nice mod
What card do you have exactly? my Sapphire HD4870 512mb (with their big new heatpipe cooler) doesn't show any of the voltages and VRM temps in GPU-Z ..![]()
I'm running version 0.3.1 aswell
I'm on the sensors page.. How odd
ive found a few posts from people who had problems with using some AMD clock program for overclocking GPU but id say try a clean install of the full driver package and see if that sorts it.
*hovers over buy button*
I guess it is a bit expensive. Think it came to about £40 including p&p.
Looks like the temps on the vrms are down by about 20C. I was hitting 100C+ originally in ATITool with the spinning furry cube after about 5 minutes. Just ran it for about half an hour and one of them is just creeping into the low 80s. It's a definite improvement but I suppose the temp drop from recycling the stock plate is even greater.![]()
So £40 a waste then?
Here's my 4870, using the sharpy method for the RAM cooling:
Snip*image*Snip
Couldn't be happier. The Xilence fans are running at about 5V and are completely silent from more than 1ft away, and the temps are absolutely fine.
i do like to help the humans every once in a while
Ok so I got the new sinks installed. Used MX-2 between the sinks and VRMs/RAM. Very easy to install. Here's what it look like.
Snip**image**snip
Going to fire up ATITool and see if it actually makes any difference to the temps.
