new case reccomendation?
7 Jan 2009
Hey guys,
Looking for a new case for the rig in sig,
my budget is £60 max,i know its not much but thats all i have.
I bet it isnt possible to buy a full tower for that budget? am i having a laugh? :D
if not just a standard case,but room is a must.
please could you link me to some on OC,ers.
thanks
Shane
The 300 is a good case, i have one. Its build well and has excelent cooling.
however i bought mine when they were 30 quid'ish. they are not worth what they are selling them at now.
Antec should have left the 300 as a budget gaming case.
thanks for your replies chaps,
came across this...what you think?
removed the link to prevent any problems with OCers rules :)
this is the case name...googled
Asus TA-M11 Black/Silver Midi Tower
Don't link to OcUK competitors, it's a fast track to a ban.
I have the CM-690 that was previously mentioned, it's a nice case.
Just out of interest, why do you want a full tower?
opps sorry didnt know it was that bad on linking to other sites,il remove the link now.
would seem a bit harsh if they did ban me just for that,Lets just say Ocers would loose my custom for good if that happned.
well the 690 after shipping and all is too expensive,and why would i like a full tower? the space hehe
Ah ok, wasn't sure if it was just for the room of for watercooling in particular.
If the CM-690 is a little too much you could try the Coolermaster centurion 590. From what I remember it's cheaper than the 690 but very similar spec wise.
