Vista 32 & 64
23 Dec 2008
I have the Ultimate so got both the 32 and 64 bits media.
Say if I install 32 bits, would Vista uses all 4GB of memory which I have installed?
Also, compared to 64 bits, what do I lose if I use 32 bits, I mainly use the PC for gaimng actually no business applications except once in a while some audio editing and a bit video conversion. MOstly for gaming and the games I am currently playing are
Call of Duty 4 and 5
GTA IV
Fallout 3 (will install later)
BF 2142
Gear of War (not bought yet maybe later)
Have you folks heard of "Reborn Card" or "Recovery Card"?
It is a PCI card which takes a snapshot of your hard disk image and everytime you reboot your machine, it restores to what it was before.
By definition, every reboot removes everything you have made changes to your hard disk including virus...registry entries ... so it is also used as a hardware anti-virus device apart from being a ghost-list device.
I have just purchased a new one which supports 64bits and I am all set now.
Happy man now!!
Happy man now!!
Waste of money. Windows SteadyState does that for free.
Where I might find this SteadyState? If it is idential function, I am more than interest to know.
BY the way, Window Vista and I believe Winodws 7 will also solve the fonts issue that persists in Windows XP.
I guess this is a technical matter of anti-alising. At the same resolution, the fonts look much sharper than in Windows XP, thus I do not feel text looking smaller in Vista compared to Windows XP.
Thanks Burnsy2023! I have found it and red it. It is exactly what I want. And I believe it may be the way that hardware card for this purposes work!
Had I know it a little earlier I would have saved HK$520 plsu a USB Floppy Drive for installng the card from diskette which costs another HK$180!
But my hard drive has to be bigger, I wish I had purchased the VelociRaptor 350GB then!
