Right, I had a stable overclock at 1500 FSB, with 1.5 volts in BIOS.
I had completed 25 passes of Intel Burn Test at maximum stress. Temperatures according to nvidia monitor, realtemp, coretemp were not hitting above 70 degrees.
All was fine, the test over, I downloaded OCCT from the internet, installed and ran it. 5 minutes later, I saw my Vcore was reported as 1.56, even though I set it to 1.5 in BIOS. Then, my pc just switched itself off, just like a pwoer cut. Damn I thought, I must have killed the cpu. I switched the pc on again, it lit up for a second, then died again. I switched it off in the wall, waited 2 minutes, and turned it on again. This time it came on as if nothing was wrong. I loaded setup defaults in BIOS, just incase.
Anyone know if my cpu was dying? Or was it something else?
