- 31 May 2004
- The 'Toon, UK, in Europe
Even though you probably won't connect it up to a monitor, unless your Motherboard has a built in GFX you can't remove the gfx card from the system totally.
Complete video removal is possible.
I'm running completely headless on mine.... definitely need a card in there for setup, but it's ripped out as soon as I'm done. On the mobo I'm using, the BIOS is set to ignore POST errors and it tootles along fine without it. I reckon with sufficient fiddling, coffee and visits to WeGotServed and Home Server Hacks, it would easily be possible to do a headless installation not unlike some of the Tranquil boxes, using a bootable USB stick or a DVD image of some kind.
If I need to do any heavy & direct tinkering, I'm at the point where I'm pulling it apart anyway, so random PCIe card gets dropped in for brief tinkering and removed once I'm done.
Day to day operation of the server (via the WHS Console or RDP) is spot on without the card in place as well.
EDIT: was headless until the onboard gb ethernet decided to poop out around 11pm last night when we were watching something. Several fix/reinstallation/other OS attempts on the mobo gave no joy, so a 100mbit card had to go in briefly to get some bits off that hadn't yet been backed up elsewhere.... now running a Gigabyte GA-MA74GM-S2 as the shop couldn't source an identical replacement this morning when I went. Six SATA ports to fill (5 already) plus a couple of PCIe SATA cards bought for other things. Gonna need a new case after all this!
i know i never do lol
