Looking for a new system in the region of £400, A GFX card will be bought next again month, I just want to get best bang for my bucks this month and, Have a system up and running.
Currently i have a 3Ghz Celeron on an old MSI 478 board.
The only hardware i want to take from that is the PSU (Hopefully) and the two optical drives.
My GFX card is a powercolor X1950 AGP. Keeping it for the old system.
I have a Maxtor external SATA drive in a caddy that i plan on using internally.
This system will be used mainly for browsing the web and, Gaming.
I'm not a hardcore gamer though, I do want the best performance possible for my money. I will probably try overclocking, Never done it before (Except my GPU through ATITool) So any headroom in that department would be great.
One issue i have is the PSU, I dont know if it is compatible with the newer mobo's. It's a TRUST 520W Pro PSU Low Noise Big Fan , Will that be OK ?
So for a barebones quick setup, I have came up with this:
Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB) - Retail (£160.99)
Would it be better going for the older Q6600 65Nm chip ?
Asus P5Q Pro Intel P45 (Socket 775) PCI-Express DDR2 Motherboard (£111.54)
Good board right ?
NZXT Alpha Classic Series Silent Midi-Tower Case (No PSU) (£49.44)
Will be sufficient to keep costs down ?
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) (£33.34)
Better with PC2-8500 ?
Akasa AK-965 CPU Cooler (Socket LGA775) (£12.64)
Just to get started, I might upgrade at a later date.
Sub Total : £319.95
Shipping : £9.99
VAT : £49.49
Total : £379.43
I could go £420 ~ £430 at a push.
Good board right ?
Sub Total : £319.95
Shipping : £9.99
VAT : £49.49
Total : £379.43
