Caporegime
- 13 May 2003
- Warwickshire
Did nobody get it?
I'm a little concerned at people not getting them. I know that sometimes L4D messes up and doesn't give you the achievement...and that if you go idle or the game starts before you connect (e.g. the first level starts rolling) you won't get it... But this seems a bit too much for just those reasons.
Definitely on one of the fragM servers, right?
I'll have time tomorrow to look at them more I hope.
I know that myself ([OcUK]MDK), Shooter, and Spudgun didnt get it. Not sure about lunix.
I also know that both myself and Shooter went idle at least once if only for a short while, however Spudgun says he definitely didn't go idle at all.
Anyway I thought the deal with going idle was that the only achievements you sacrifice are the ones that your AI character gains whilst you are idle. However Googling the answer quickly doesn't seem to have cleared it up one way or the other.
Some people are saying that they got an achievement if they went idle but not if they even died once (on expert). I'm just not clear on what the exact requirements are for gaining an expert achievement, as I think I'd need to be sure of that before leading you to believe that there's a problem with the server.
Things I know:
- don't change difficulty otherwise you have to restart
- you must live through the entire campaign or at least be alive to get onto the escape vehicle
- lagging when joining and therefore joining even slightly late will make the server think you weren't there for the whole game so you won't get the achievement
Things I don't know:
- does dying at all forfeit the achievement
- does going idle even for a few seconds forfeit the achievement
no lag, no advertising and other junk.. perfect servers
