I charge £25 per hour :S
You say it in a worrying way! I'm a digital developer at a big agency in Manchester and Im on less than that
Aslong as you're charging enough money to be happy with and think you are charging the right amount for your skills then don't worry about it!
My freelance rates change all the time but I normally charge a flat rate which is determined by what the project entails.
On a normal web developing project if someone offered me a project for £25/hr I would most likely take it but that's all dependabt on my current situation![]()
rather then any coding, and i get paid just under £50 per week with around 50 hours work atm thats £1 per hour. as a customer and NOT a webtechdeveloperhtmlcssjoomla(whateverthatis)guru - I personally would never select a supplier to do ANY work for me on an hourly rate basis - "fixed price for the job" is fairer (from a clients perspective) and the norm for us - probably the flavour of things to come bearing in mind the current "state of the nation" and all that!
If you are developing any bespoke stuff, work it out as multiples of your daily rate, but be careful because most customers want a fixed price for a specified project. Any over-runs will generally come out of your time.
so... can we see some URLs?
had a feeling it'd go quiet when i requested some examples![]()
The amount my company charges does not need to be justified as by all accounts the values are sensible... otherwise we all might as well post up sites... we want to see these high flying ones.The amount my company charges does not need to be justified as by all accounts the values are sensible... otherwise we all might as well post up sites... we want to see these high flying ones.
Didn't reply cuz I thought you were on my side also wishing to see the same sites i requested... then you went and turned on me! - but yes, I was maybe a bit hasty...
Seriously, what exactly were you smoking when you came up with those figures?So for Third Sector (charity/non-profit) you'll be looking at rates of £300-£400 per day, in the private sector you will be looking at £500-£750 typically, and if you have a niche skill or are working for 'platinum' clients, you might charge £750-£2000.
