Hey everyone
I built a PC for my boss, and installed Vista 64 Ultimate on it. As soon as it loaded into Windows I turn off UAC (which is normally my first step in Vista anyway) but after it was built, he took it home and enabled UAC when it notified him that there was a security issue. After that was done, he installed Fallout 3 on the PC. Now, whenever I disable UAC to get rid of all of the annoying messages that regularly appear, Fallout 3 will not load up any saved games unless UAC is enabled and the "Run as Administrator" option is selected in the compatibility settings. Now his user account on the PC is an Administrator so does anyone have any ideas as to how I can get Fallout 3 working without UAC turned on? I have it at home on Vista 64 Ultimate and have never had UAC on, and my Fallout 3 works without issues (it was installed when UAC was off though).
Steps I have already taken are as follows:
I've removed Fallout 3 from the PC, rebooted it and then reinstalled the game. It still crashed when Fallout 3 was trying to load a saved game.
I've renamed the old Fallout 3 folder in My Games (save game location), copied it and then renamed it back to Fallout 3 and still get the same issue.
Uninstalled Games for Windows Live, reinstalled that to no avail.
Uninstalled MS .NET framwork 3.0, reinstalled it by installing the game, upgrading to 3.5, and still nothing.
Installed Fallout 3 to a completely different folder on the same drive (in case UAC had stored references to the original folder and was preserving those). Didn't make any difference.
I have tried reinstalling and running Fallout 3 under a different user in Windows Vista Ultimate 64.
I've done all of this and yet, with UAC turned off, the game still crashes regardless of whether I try and start a new game, or load up an old one. The crash is also always at the exact same point of loading (as indicated by the clock timer that Fallout 3 uses on loading screens).
Anyone had this same issue? I see many on the internet are also experiencing it, but none of the fixes work (except of course enabling UAC and granting Administrator privileges to the program compatibility section of the .exe). I know enabling UAC is the solution, but it isn't the solution in this case as UAC is an annoying "feature" in Vista that we could all do without.
Thanks for reading
Thanks for reading
