A plane is standing on a runway that can move (like a giant conveyor belt). This conveyor has a control system that tracks the plane's speed and tunes the speed of the conveyor to be exactly the same (but in the opposite direction).
Will the plane be able to take off?
That's an odd version :|
In your case the plane would actually take off. In the more common scenario (where there is no movement of the aircraft relative to its surroundings) it would not.
im sure its something you all wonder about but if i have a metal rod 10 miles long and pull it at say 1 metre/second how long before the other end moves assuming its frictionless and wont stretch, ok its not instant or speed of light so how fast is that motion transfered![]()
If it doesn't stretch then the ends will move simultaneously, simple as. If this doesn't seem realistic to you, it's probably because it's actually impossible for a material 'not to stretch' and so the above model is inaccurate. Any calculation assuming stretching is involved would take into account the 'Young's Modulus' of the material involved - a measure of stiffness [insert joke here
Nevertheless, since the OP has stated that in his MODEL of the situation, there is no stretching, then yes...both ends will move simultaneously.
