(Talking about the original question now)
Electrons moving doesn't cause electricity, the charge they carry does. Electrons actually move quite slowly in an electrical circuit
since electrons inherently have charge, you're really nit picking imo.
If the brakes are applied and the wheels are all on one axle it will cause the aeroplane to take a nose dive. Think about itWhat happens when the wheels stop turning in the air?![]()
Think of a car on a treadmill driving forwards at the same speed as the treadmill is moving backwards. It will not go anywhere.
Now take that car, stick it in neutral so the wheels are free wheeling and therefore are providing no forward force. Now stick a big propeller and wings on the car. Now the propeller is providing the thrust. As the wheel are in neutral, they will just spin with the treadmill, with the prop pushing the car forwards. It doesn't matter how fast the treadmill moves, as the wheels are free wheeling they are providing no backwards force (ignoring the small friction they create) and so the plane will move relative to the air and thus create lift.
I'm waiting for it to click
EDIT: Damn fast moving threads.
Blow air from the BACK and the plane stays on the ground.
Blow air from the front and you're only giving it a hand in this case, it'll go up, as its getting air over its wings, but wont move its position on the ground.
:facepalm:
.....and we're back to step one. I'm not a plane, and dont have the benefit of engines that push against air.
If the brakes are applied and the wheels are all on one axle it will cause the aeroplane to take a nose dive. Think about it![]()
Sigh
Engines don't push against air. People used to think travel to the moon would be impossible because the rockets would have nothing to thrust against.
:facepalm:
I'm unfortunately not a plane, and don't generate motion like a plane would.
They definitely do push/pull against air. What do you think they push against when a plane is in the sky? Pixies?
To the OP. If you assume that it can't stretch, then it shouldn't compress either, then it should be instant.
Well, ignoring the somewhat rude and intolerant facepalm, in my strap on wing and gym scenario you are a plane and you do generate motion and lift in EXACTLY the same way up to the moment after take off.![]()
Sorry, I am assuming jet engines. You must be imagining airscrews (propellors).
Simultaneously
AAARGH! It would have to be in a vacuum to not move under its own power!
In your case the plane would actually take off.
Its the original version.
And in any scenario involving a treadmill and a plane it takes off.
What the **** is this thread on about?
People who can't grasp basic physics obviously.
