£400 budget
10 Jan 2008
Nottinghamshire
Hi all,
I'm due to build my PC in 2 weeks. Just trying to get a rough list together of what I want to get.
Core i7 920
ASUS Rampage II Extreme X58
6GB (3x2GB) Corsair Dominator 1600Mhz
GTX 285 / 295 / 4870X2 (Undecided)
NEC MultiSync 24WMGX3 Professional Gaming 24"
PSU / HDD (Undecided)
Vista 64 Ultimate
CPU / GPU High End Water-cooling
What is the best graphics card to get for my budget?
Is it better to get a single card so you don't get micro stutter?
Is there anything new coming round the corner so I could just get a gtx 260 / 4870 to keep me going till then so I don't have to mess around with waterblocks too?
I want something that will play every game at 1920x1200 max settings, [unless new gpu coming soon].
I appreciate this has been asked a ridiculous amount of times but I just want to get an up to date opinion from people.
Thanks all,
RoEy
I think the XFX 295GTX OcUK got on offer this week for £402.49 would be a great choice. Its the most powerful gpu out atm and i doubt it'll go lower then that price for a while nor do i expect any new cards anytime soon as the 295 only come out a 3? weeks ago.
For every game on the market at max settings (including AA), you're really looking at a 4870X2 or a GTX295. They are very expensive though, and bear in mind the drawbacks that multi-GPU can bring, such as poor driver support and high power consumption.
New cards are due beginning of Q2-ish I've heard.....so I think your best bet right now is to buy a 4870 1GB or a 260-216 and use that for now. They're still very powerful cards.
4870X2 or a 295GTX, whatever takes your fancy. However I would argue that the 295GTX isn't worth the £80 odd over the X2.
I would go 4870X2, you wont notice a huge amount of difference to the 295, and its in the middle between the 260/4870 and 295 in terms of price, which means if a new gen comes out, you could probs justify it :p
Thanks for info so far.
Just makes it extra difficult for me as I want to water cool whatever gpu I get. Might get the 4870x2 as that should last me a while with a koolance water block.
Does it suffer from micro stutter or is it a myth?
RoEy
I 'think' new cards are due around april, you might want to pick up something cheap and just hold on till then, a block for either 4870x2 or 295 would be around £80 so bear that in mind
myself and a few other people i know have 4870x2's and we have never seen microstutter, i think i read that it was only the older NV cards (such as gx2's) and old drivers for the ATI that suffered from it (like 8.7 or something)?
I could be wrong on the above but nothing but a happy 4870x2 owner here without microstutter :D
As your going for WC as well the blocks are already out for the x2 and you have plenty of choice, the aqua computers block makes me drool! Will be a while before you get 295 blocks (unless someone can correct me!)
Cheers for info. I'm currently looking at the Koolance waterblock for the 4870x2.
Looks sweeeeet.
Thanks again to everyone.
RoEy
