want to get a heatsink that maybe able to run the above cpu without another fan.
Current setup is TJ09, 4x 120mm yate loon @ 800rpm, 8gb dominator no fan, gtx280 and 4x ssd, atm I have a zalman cnps9700 running at the lowest setting and keeps the cpu about 40 idle 65 at 100%
the cpu is at stock and don't plan to OC
was looking at these which would be best for the above task or is another you would recommend
Scythe Orochi
Scythe Ninja II (have this in my fileserver so could swap with my zalman)
Coolermaster Hyper Z600
Asus Silent Square Evo
Scythe Orochi
Temps?
