-== Zotac 55nm GTX 260 Core 216 - £195.49 inc VAT ==-
9 Nov 2003
Leeds
Cheaper than value parts but with a free game and 5 year warranty from a good brand, latest 55nm part on these also. ;)
Zotac GeForce GTX 260 "55nm Maxcore" 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (288-OK101-000ZT)
Immerse yourself in a world of phenomenal visuals and screaming-fast performance with the ZOTAC GeForce GTX 260². Powered by 216 blazing-fast processor cores and 2nd Generation NVIDIA Unified Architecture, the ZOTAC GeForce GTX 260² is ready to take on Microsoft DirectX 10, OpenGL 2.1 and NVIDIA CUDA-based 3D games and applications at extreme high-definition resolutions. With it’s 896MB of high-performance GDDR3 and 448-bit wide memory interface, the ZOTAC GeForce GTX 260² is ready to take on all 3D games and applications with ultra quality textures for brilliant visuals. NVIDIA PhysX technology enables the ZOTAC GeForce GTX 260² to immerse gamers in a world of realistic weather and explosion effects – blurring the line between reality and the virtual world like never before.
- Bus Type: PCI Express 2.0 (Backwards compatible with PCI Express)
- Memory: 896MB GDDR3
- Core Clock: 576MHz
- Shader Clock: 1242MHz
- Memory Data Rate: 1998MHz
- Processor Cores: 216
- Shader Model: 4.0
- Texture Fill Rate: 36.9 Billion/sec.
- Memory Interface: 448-bit
- Memory Bandwidth: 111.9GB/sec.
- API Support: Microsoft DirectX 10 and lower, OpenGL 2.1 and lower for Microsoft Windows
- Display Connectors: 2 Dual-Link DVI-I, HDTV + TV Out
- RAMDACs: Dual 400MHz
- HDCP Capable
- HDMI Capable
- 2-Way & 3-Way NVIDIA SLi Support
- Card Dimensions: 266.7mm x 95.3mm x 38.1mm
- Supplied with voucher for Mirror's Edge game
- Geforce with CUDA
- PhysX enabled
- CUDA enable
- Includes Far Cry 2 Full Game
- 5 Year Warranty
Just £195.49 Inc. VAT
BUY NOW!
sounds good, looking for a new GFX card for my new build, and was waiting for prices to reduce.. is it worth waiting a while to see if the 285's reduce a little?
For the price difference nothing Nvidia will touch this for a while, the 295 is getting very thin on the ground and Nvidia cannot make enough of them so the 285 will be staying at a higher price for a while yet. :(
Do these use the smaller 260 cooler? or does it still use the bigger cooler (from the 65nm cards)?
I've seen these for ~£200 so good price OCUK, i will not be getting one because i recently got a4870 1GB which is very slightly behind this card and the fact that everywhere i go i see the XFX version with bundled Far Cry 2, so forget it. Other then that excellent card/deal OCUK.
I've very tempted to get this card
- Warranty: 2 Year
- Geforce with CUDA
- PhysX enabled
- CUDA enable
- 5 Year Warranty
Looks like you've got a typo in there... it's definately a 5 year?
Also I've just read a couple of reviews and one mentions you only get 14 days from date of purchase to register the card and qualify for the 5 year warranty. Otherwise you only get 1 year.
Can you confirm this please? Seems to be purposely cutting it a bit fine don't you think as it could easily get held up in the post. Either coming from OcUk or then getting the registration out to Zotac in time?
