First pic (stage 16) is a bit confusing, that ball appears to be falling on the right?
yes
what i did with that one is i balanced it on the tip of that top triangle and its stayed on for a good 5 seconds, then it slowly fell
Isn't this like the Super Stack 2 that was on the forums few days ago?
im playing super stacker 2 nowand im stuck on level 28! someone help...
PICTURE!!!!!!!!!!!!!!!!!!!!!!
i get lots of faces + 1 triangle same size as them ^
http://www.imagebee.net/images/8tmlhnj557aay43ey6r.jpg[IMG]
i get lots of faces + 1 triangle same size as them ^[/QUOTE]
This is the better balancing game :p
Just throw all circles from the top and by the time they reach the last triangle you have enough time to put it down on the two tiny circles at the bottom.
They won't roll off the screen before the level ends :)
