why would you need all that processing power for browsing the net, if you need more power you need an ultraportable, which costs around 4x more for anything decent.
You will never acheive this. Once these netbooks arrive you will bemoan the fact that these "Dual Core x86_64, DDR3 with SSD drives" are not yet perfect and will want the Quadcore, DDR4 and Super SSD netbooks.
The latest software will always keep you wanting more.
- Small < 10 Inches
- Light < 1.5 KG
As soon as you start sticking in things like DDR3 and high spec CPU's you loose some of the above advantages.
That criteria defeats the whole point of a netbook. The current generation models are proper notebooks - cheap, ultra portable, and finally low power consumption thanks to the atom resulting in high battery life.So when do you think we'll finally see a "proper" netbook?
And by that I mean Dual Core x86_64, DDR3 with SSD drives.
Kinda fed up that nothing out there is "perfect" as yet![]()
Sounds like you want something beyond that like an XPS 1330.
DDR3 uses less than DDR2 and SSD uses less power than normal hdd.
Dual cores are still too much given that current N270's atoms sit at 0.65-2w. SSD's are nice but as james said debatable on cost as well as their benefits, especially the cheaper variants used in laptops. DDR3? Cost wise at present no chance.The dual core atom is only 8w, DDR3 uses less than DDR2 and SSD uses less power than normal hdd.
