- 7 Feb 2004
I was wondering if anyone knew much about this software as I am trying to recover some information off a drive that is encrypted which blue screened.
I was wondering if it is possible to use another computer with the same software and some how unencrypt the software using that computer.
If you have a normal computer with pointsec on it then you can go into control options and uninstall the pointsec if you have the correct level of access which I do.
When you do this it gives you the option of selecting the drive that is to be uninstalled. Is it possible to hook up the faulty drive and uninstall pointsec in this way or is it lost for good?
Thanks
Thanks
