Yea water cooling makes it look really cool and snazzy I've got it in my TT amour case two loops UV green and UV Blue worth having the window for
Ninja
Got any pictures you fancy sharing?
Ninja
I used to run 2 waterloops but bai eck was it expencive to buy the parts! ended up using 1 loop but a different chassis ( Mountain Mods U2UFO )
If you look at my first picture you can see there are a lot of holes for screws in the mesh, this is so that you can replace the 120mm fan with 4x 60mm fans:
Bit off with the sizes there - the holes are to mount 4 x 120mm fans instead of the single 230mm
I admit Flare they are REALLY nice but stupidly expencive for next to no mod cons! But the powdercoating looks really nice and my PA120.3 fits perfectly!
@Flare: Did you need an ATX extension cable for the PSU?
I have the same PSU and was looking at getting this case, seems pretty good as a replacement for my TT Armor which doesn't seem very capable of cooling a GTX280 and Phenom.
Without sounding a bit "feminate" Flare ive heard using a pair of tights cut up covering the fans will act as a good filter![]()
Thanks for that info Flare, This certainly is a stunning case imo, looks like i will be getting it.
Does the 230mm fan on the side shift much air and are 4x 120mm's gonna move much more do you think?
I noticed you temps on the GTX280 are very good for the stock cooler, mine currently idles a fair bit higher than that
And the highest load temp ive seen is mid 90's thanks to 3d mark Vantage and for some reason Fallout3 ???
