Can't join in CSS game??
8 Jun 2006
Hertfordshire
Guys
Haven't played in ages but everytime D2 loads up I'm a camera in the top right corner of B bomb site and I can't join T's or CT's then I disconnect from the server??
It's really beginning to bug me?
What am I doing wrong? grrrr :(
Are you on wireless? Sounds like a problem I get, its to do with "Received fragment out of order". Look in your console when your in game to see if that's it, and if so the only thing I can find that actually fixes it is by going to a wired connection or changing your router. I have also heard something about changing the firmware but that didn't work for me either, but it comes and goes with me so it isn't affecting me most of the time.
No mate hard wired to router?
Could be some sort of corruption, tried verifying the integrity of the game cache under the game properties?
I seem to join the game as a camera? Can't join one team or the other then I get disconnected?
Got the error below just before I disconnect?
Warning: using WorldTwoTextureBlend on a non-displacement surface.
Support for this will go away soon.
- Material : de_dust/groundsand_blend
- Surface center : -1920 2440 0
Warning: using WorldTwoTextureBlend on a non-displacement surface (material: de_dust/groundsand_blend). Support for this will go away soon.
I think that's when you take control of the camera. There's a key to press which un-controls you of it, think it's N or Space, I'm not sure.
Nope, that's cs_office which is an original map. Try spamming "M" key and keep clicking join a team, sometimes I also get this problem too and that solves it for me, although I have no idea what that error is all about :(
Installed any custom model packs or tweaked any gfx settings manually?
Seems like maybe a re-install of CS:S might help at this juncture, just to rule things out.
No custom map, kept hitting M but no joy, will try the N key next then if not uninstall everything and start again :)
Thank guys will report back
