A HDMI or An HDMI cable?
Dialects are not wrong - they are a side effect of introducing a standard language over a large area and as such are part of that language whether you like it or not.
The other one is sixth, most people pronounce it sicth, which I believe to be the correct way of saying it, whereas some people pronounce it sixth, which is wrong I know, but everyone still knows what you mean.
I say sixth even though I know it's wrong, I'll always say sixth, sicth sounds wrong to me.
sixth and sicth sound the same to me? :confused: Can you give more accurate pro-nown-see-aye-shun for them?
I'm assuming he is commenting on the difference between sick-thuh and sicks-thuh (with less emphasis on the thuh than I point out :p).
I mean sick'th and six'th, pronouncing a ck sound as in sick or an x sound as in six. I say six but with a th on the end.
And yet, somehow, every year the percentage with passing grades increases...
Easy to do when you can "pass" with a string of Ds and Es.
When I went to school, anything less than a C was a failure. Now it seems there is no way to fail, even if you're functionally illiterate and never bother to learn anything.
I am truly grateful for HDMI cables.
I was once asked "Do scarf cabaws work wif digicall tv's?" I faced palmed, and just walked away from the customer.
Bristolian is truly shocking at times.
I would say "an HDMI" in an informal setting, "a HDMI" in a more formal setting such as work. I would write "a HDMI" since I always expand the abbreviation.
I usually get these things wrong though :p
It's pronounced 'haitch' by cockneys and other illiterate enclaves.
I have to congratulate the forum on picking up a minor mistake in about the same time it took me to spot and correct it - well done!
I think the new forum logo should be that 'someone on the Internet is wrong' cartoon - seems to fit here alright!
Not all cockneys :p
Also not related to above, I've seen in news articles and such, they sometimes put "an hotel" which I always think of as wrong.
Also, re: "An UFO" is wrong.. phonetically it is "a yew eff oh"
Its blatantly "An" because of the pronunciation of the "H" which would be "ay-tch", i.e. a vowel like sound. If there's a technical name for it then its that.
- Pea0n
What about people who say hay-tch?
In that case it doesn't have a vowel sound so there for it would be A or ay.
