- 19 Feb 2007
- Area 18, ArcCorp
Heres mine, my first build aswell(not quite finished still),
You have one of the best cases for cable management out there, why dont you utilize it ?
Someone else from Woking i seeWell, i can answer that, Those block of wires you see are unused psu wires so far, since i have no optical drives yet or hard drives, so theres no point stuffing them behind yet,
Those 2 black wires are the temp gauges on the watercooling, and i cant just make them dissapear
I guess i can run them next to the pipes?,
Other then that everything is behind the back place and hidden from view, i probabally took the worst photo of it to be honest
And not to mention this is my first build ever lol, never even dreamed of building a computer until exactly one week ago, so for my first build not bad i dont think![]()
Going water is pretty impressive for your first build. One thing though, wouldn't it be better to have the rad fans facing the other way so they exhaust the air? Or do you have the front fans blowing out....
Mase its looking good![]()
Nice. Why is the tubing from the rad and the gpu block split in two?
My first build:
Upgrades yet to come...
Finally finished my second watercooled HTPC.
Just waiting for my Xonar HDAV to come back from RMA to fill that empty slot.
I've done the mod to the Apogee drive to make it 18W but it's now the noisiest thing in the system! I think I'll make a foam jacket for it to quieten it down.
Spec is;
Silverstone CW02 case
[email protected]
P5K-E
4gb PC8500
8800GTS 512mb
2 x 640gb WD black
1 x 1tb Samsung F1
LG Blu-ray/HD-DVD drive
Hauppage HVR-4000
Enermax Infinity PSU
Asus Xonar HDAV (back soon!)
Cooling - 120.1/92.1/Apogee Drive(18W mod)/EK VGA acetal supreme/Swiftech microres
Finally finished my second watercooled HTPC.![]()
That is superb mate.
Makes me want one for my Home Cinema
Is it silent?
Very nice, love the case![]()
What are the temps like? where is the 92mm rad hidden!? At the front?
Bump with a few updates of mine also:
