**EMPIRE TOTAL WAR**
Yeah I've got the box, manual, 2 discs but no map or code for the units. Looks like they have put a standard copy inside a collectors box, doh.
Dont know how it works for the special forces edition, but I got my extra unit code in an email from the people I ordered it from. I've already added the code in.
How long did it take everyone to update the game on steam? It's only on 2% and its been 45 minutes.
only took a few minutes to update for me.
Although i wish they'd included a fix for the jerky campaign map in the update. Everything else is brilliant....
What specs do you need to run this smoothly with high graphical settings at 1028x1024?
Not sure what the minimum would be, but I am running it at 1280x1024 with everything on Ultra (except shadows which I have on High) with 4xAA and 4xAnisotropic. Its running pretty smoothly.
Thats on an AMD 64 X2 6000 with 4gig ram and a Geforce 8800GTX (768mb)
Loving the game atm.....can't stop playing it.
HOWEVER, has anyone noticed the campaign map runs a bit jerky? I've got a GTX 280 and the battles run fine with everything on Very High....but when it comes to the campaign map, it seems to be jerkier. Even when I put the settings on Low and turned off the AA things still didn't improve that much.
Anyone else finding this?
Aye, I get that too when panning across the map, turning AA off helped it a bit though. AA also seemed to cause a row of flashing pixels at the top and left side of my screen too, although this could be a graphics driver issue, not a ETW one.
you need to sail your trade ships to 'trade zones' for example off the coast of brazil then park them in the right spot and they start trading! To get their from Europe etc you need to use the transition zones that lets you sail between maps.
Do I just leave them their once they are in place?
Has anyone else had problems installing this?
I have the Sf retail version and although steam accepts my key it the refuses to install OFF THE DISKS because 'the servers are too busy'
Does anyone know if it's possible to either convert a trading port to a navy port, or build a navy port? I'm trying to build up my naval presence around the 13 colonies and all the ports around there seem to be for trade.
Maybe I just have to capture one....
