Download and install instructions
Firstly, install 7zip 4.65 from here
^reinstall 7zip if you've used my old reg entry pack..
32bit users
64bit users
Navigate to the 'black' or 'normal' folder, save the dll to your X:\Program Files\7-zip directory, replacing the current file that sits in there -close 7zip before doing this if it is open.
Open 7zip, click Tools, Options, select all, click ok. (untick any filetypes that you don't want 7zip to be the default app for)
Restart PC for icons to be rebuilt.
info..
After waiting a few years for a 64bit free resource editor, W3bbo from msfn has made one, it's still in beta, but fully functional for the basic use I need from it.
Big thanks to W3bbo, without him, this wouldn't be possible.
Here is what they look like, I use the black ones in Vista and the normal ones in XP.
Each icon has a 48x , 32x and 16x icon, for different folder views
These are the filetypes that I've changed them for.
http://bleddyn.co.uk/7zip/icons/7zNormal64.jpg
http://bleddyn.co.uk/7zip/icons/7zBlack64.jpg
If anyone wants other icons changed too, let me know. I've never seen any of the others in use tbh
I'll have a look now to try and find the default Vista folder icon, so I can make a third set for that too.
When official 7zip updates are released, I'll update the dlls, and the file version number that sits in the same dir. So you can quickly tell if I've released a new version.
32bit users
64bit users
info..
