Upgrade - Worth It?
11 Apr 2003
Notts
Hey all,
I mostly game on the 360 now, however with recent games such as DOW2 I have been finding that my PC does not run them so well, my question is however would it be worth upgrading the graphics card?
My Spec:
AMD X2 4800+
2GB PC3200 DDR
ATI 1900XTX 512MB
I am looking at this card to upgrade to:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-120-XF
A) Now would I notice much of an improvement over what I already have?
B) Would it be worth upgrading taking my CPU and RAM into account?
C) How much better is the 4870, to the 4850? Is it worth the extra £50?
Thanks all!
Jcb33.
The CPU/RAM will limit the card, but you will still notice a big difference compared to your present card. and if you upgrade your mobo/cpu/ram in near future you can always transfer the gfx card across
sorry man but the cpu and ram will just be a bottleneck for that card.
Very true but still an big improvement. I went from a X800XT to a 8800GTS 320 with an overclocked X2 4200+ @ 3Ghz and saw a big leap. I got another massive leap upgrading to a 8800GTS 512Mb and yet again to a 4870 (although much smaller than the 8800GTS 512 leap)
However, I was still being held back by the 4200+ and when I got a q6600 I saw yet another massive leap (the cpu held me back in some games by 25% - crysis went from 29 fps to 40 fps)
So yes, you will see a good improvement but unless you are planning on upgrading your cpu/rig shortly I would stick with the 4850 and save some money.
I was in a situation similar to yours a while back, and decided to keep my old rig for a while before upgrading. Even with a fairly dated processor (AMD Barton) I got a pretty noticeable improvement without spending too much on a graphics card, and was able to game quite happily for a while
An ATI 4850 would probably do you for now and will give a good performance boost if you want to keep your rig.
Ideally a full upgrade would be great if you are willing to spend some cash; and in this case a 4870 would be good. However, if you mostly game on the XB360 then you might not find a complete new rig to be particularly "good value".
I recently upgraded my graphics card from an X1900XTX 512Mb to a 9800GTX+.
The increase in performance by swapping the card out for the 9800GTX+ was quite simply astounding. :eek:
The X1900XTX was no slouch but getting a bit long in the tooth and more recent games were not able to be played at maxed out settings.
Whereas now with the new card, every single game I have installed over the past few weeks is simply flying along with everything ramped right up to the maximum. Frame rates are a similar story.
The rest of my system spec is in my sig, it is a rather modest system by todays standards but by upgrading the graphics card I think I have added a good few months onto the old dogs lifespan. :D
