If I remember the notes I think you do need both as it uses models and assets from them.oh, do you need EP1 & 2 to use the mod?
I don't have them on the PC, played them through on the xbox orange box.![]()
Readme says it requires "Fully installed and unlocked HL2 / EP1 / EP2; Make shure, you have started those games in the past." Anyone know if it needs Lost Coast as well?
You only need HL2, EP1, and EP2 to make it work
wheres best places to put up high res screenies as imageshack wont let me cause too big(prefer somewhere where i dont need to register)
With regards to how easily things die that would most likely be an autoexec.cfg config file which you could either delete to return to vanilla values or edit in notepad to chage to how you want.
I can't remember the directory it will be in though and I don't have steam installed on my lappy to check at the min.
