Deleted member 66701
OP
Second hand, nearly new bits are the key
Got the clock set for £100 with only 3000 miles use - saved £250.
Carbon dash - £40 from ebay - saved £70
Manifold - £80 - saved £210
Seats - £200 - saved £260
Steering wheel and QR boss - £50 - saved £110
And so on. Plus I had the donor car already - I'm not factoring in the cost of that - you could easily add £500-£1000 if you needed to buy a donor then refresh all the parts used.
