Right, so upgrade time is round the corner for the Brakes on the S3 and I've decided I can't be bothered (read: afford) to upgrade to the Brembo calipers so I'll have to stick with what I've got and upgrade everything else instead on the Brakes.
Here's my concern: the state of the calipers currently. In the Swiss Mountains last year a bit of spirited driving caused the brakes to overheat somewhat. There were very large plumes of smoke billowing from each wheel as we pulled to a halt at some traffic lights. This has caused the paint (lacquer?) on the calipers to erode and has left me with this:
Drivers Side:
The worse Passenger Side:
Should I be seriously considering doing something about this or should I not be too bothered? If I need to do something, I assume a sand down and new paint layer would suffice? If so what's the best thing to use. I have seen Foliatec Caliper paint as an option but wondered if you could recommend anything else.
If I do need to consider painting, I need to choose a colour
I have for the benefit of the unimaginative produced the following. Cast your votes please but do bear in mind I'm only going to bother if the calipers need to have something done to them. Too much like hard work otherwise
Original:
Black (you might ask how different this really is):
Silver (still subtle but will it suit the colour of the car?):
Red (my favourite colour, but I don't have the Brembos so can I really get away with it?):
Cheers for your help as always people
Drivers Side:
Original:
