Hi all
My motherboard has the 790i Ultra chipset. This can get very hot. I use good quality air cooling, my case (Antec P150) is relatively small and with two 8800GTs, a couple of disks there is not a large degree for airflow.
Last night I was playing Crysis Warhead and after about 30 mins, it just froze on me. After rebooting, I checked the NB temp in the Bios and it reported 80 degrees centigrade. The bios is set to shut down the machine when that temp reaches 85 degrees so I suspect that's what happened!
When idle, my PC is very quiet. The fans on the 8800GTs emerge from the ambient noise during game play and that is okay... the fan on my Thermalright goes upto 1250rpm (ish) at max but still can't be heard.
The motherboard also comes with an extra (40mm) fan that sits on part of the northbridge chipset heatsink - I've used that but reduced the RPM with a Fanmate to reduce the noise.
Anyway, I'm looking for a bit of advice. The MB cooling supports water cooling - it's called Fusion block and is used on a number of Asus boards and uses 3/8 connectors.
Preferrably I want a solution that will fit in my existing case and be quiet!
Can anyone recommend a water cooling solution that just works on the motherboard (not CPU, GPUs or memory) but would allow expansion in the future?
Moving to a large case such as the Antec P182 is another option but I would like to avoid that additional cost if possible.
Any ideas?
Any ideas?
