Splitting a console image over 2 screen
12 Jan 2006
Hi all,
Is it possible to buy an adaptor or a switch or something to take part of a display and send it to 2 different screens.
I have 2 lcd screens at home and i am trying to take the output from a 360 and send each half of the split screen image to 2 different screens
I made a pic to illustate what i am trying to achieve better
doubt that would work.
plus your res would be weird and the image q would be not that great.
networking would be better idea.
plus any kit like that (if it exists) will most likely cost in the range of 200quid anyway...
surely there is something that can act as an interim,
for example a pc with some sort of capture card, most gfx cards have dual output so use extended desktop to send the signal to each screen
I cant seem to find many reasonably priced vga capture cards tho, its not that much more for another console
What i cant find is the words to search to get the vga output
Why not just buy or borrow another console... it will be much less hassle.
it really wont work. If you are capturing and splitting an image over vga its going to be really jumpy, also the image will be squished.
You are looking at something that can do this (just smaller scale :D):
n1blo is correct, something like that would cost more than a second 360 networked.
