need a quiter cpu cooler
12 Dec 2006
hi
currently have a cosmos s case running full set of red wing 120mm fans x 6 17db noise lvl
and 1 x 250mm case fan cooler master
problem is the cpu cooler is so noisy alaska evo blue and it aint too good a cooling either constantly getting bunged up due to plastic surrond.
current temps whilst running:
WAR game in back ground
downloading
surfing
picture file transfering
& working in excel
39 39 36 36 cpu q6600 @ 3.3ghz
just a problem with the damn fan on the cooler
spec me a new cooler not two worried on price as long as it dose the job and is quite
If you're after silence, then either the Noctua HSF, or a TRUE with a Noctua fan are your best bets.
*edit*
oh, and your sig is too large - 4 lines of text max.
Your temps look fine so you could just get a replacement fan (Noctua or Akasa amber are very good) which would save a bit of money/effort
