Another point is...
I wish I could operate my PS3 with my Harmony One remote
You can, can't you?
Maybe I'm mis-remembering, but I thought you could buy an Infrared remote kit for the PS3.
A USB IR port plugs into a PS3 USB port, and it comes with an IR remote, which you could then teach the harmony remote?
My projector came with a learning remote, but personally, I got the PS3 bluetooth remote, and I love it. I love that I can just leave it on the sofa beside me, and not have to pick it up and "aim" it when the phone rings, or whatever.
Vin.
EDIT: Just did a google, found what you need from a link on AV Forums, problem is, I can't link, because it links to the competitor that sells them.
I'll quote the post though
I had the same problem as you - I wanted to use my universal Philips Pronto to control the PS3 so needed an IR controller. I bought one of these from ***** (search for PS3 remote if the link doesn't work - its a Logic 3 remote):
Despite the one fairly negative review on the ***** website it has worked fine for me. You plug the USB dongle into the PS3 and it comes with a remote from which you can learn the commands for triangle, circle etc.
The only thing you can't do is power on/off the PS3 because the USB dongle isn't powered itself until after the PS3 is switched on. So you will still need to switch the PS3 on and off manually. However, after that you can navigate and play DVDs etc. (can be a tad slow to move around menus). I have even used my universal remote to play a PS3 game which feels really 'odd'.
There are probably more than one option available, this was just a very quick google to find something, but yes, you can get USB IR ports for the PS3, which you could then teach to your harmony. Have you ever tried the bluetooth remote though? I know it's an extra remote, but I really like it!
