Hi guys,
Been meaning to go RAID1 for ages so bought a second WD 5000AAKS. Backed up all of my data to a couple of external HDD's incase of any issues and also can remove the partition table and start a fresh.
I have partitioned off 60gb and installed Vista after having issues with installing XP (BSOD upon installation of intel chipset drivers which then prevented Windows from booting).
The array has been reported as degraded so I rebuilt within Windows Vista.
It has now reported as degraded again whilst formatting off a 300gb data partition.
As I only installed Vista around mid-afternoon today this is all rather sudden!
I have now reverted to IDE mode and booted up my WD diagnostic CD to test the brand new hdd (the one that has reported as failing both times).
A quick test reveals no problems and a quick google reports lots of weird issues with the ICH9 chipset when using for RAID.
I am now running the extended test on the disk and will go from here.
Would it be worthwhile zero'ing both discs or is the ICH9 indeed crap and I should get a proper RAID controller?
If the latter which controller is decent?
Thanks,
Chris
Thanks,
Chris
