- 27 Aug 2003
- West Midlands
Anyone else read "smart car as computer" ??
You won't get that MPG on the motorway or similar as the sewing machine engine will be revving so high.
Also as they are so small, you will certainly fold up inside if you hit anything at all.
WHY is the M3 being mentioned?
60 Miles a day in a Smart car would drive me to suicide, they are cramped, noisy and the suspension is rock hard. Try and find a small diesel alternative.
You've just summed up why the gearbox was invented.You won't get that MPG on the motorway or similar as the sewing machine engine will be revving so high.
You should do some research before posting comments like the above.Also as they are so small, you will certainly fold up inside if you hit anything at all.
Won't the gearings be set up to handle town driving and not motorway cruising, meaning 70mph might be 4k RPM in top gear?
They are certainly not cramped, in fact they are surprisingly spacious and comfortable for such a small car, but there is no way I would contemplate doing 30k a year in one.
Or even better sell it and get something not french or a smart car. i would NOT like to be doing >60 miles a day in anything smaller than mondeo sized tbh.
I have driven one. It's the size of a shoebox and is about as comfortable as one.
It's perfectly comfortable even for long trips, no idea where you get that from.
