***The OcUK Graphics Card Performance & Review Thread***
rjk
rjk
OcUK Staff
8 Aug 2007
NEW CARDS ADDED - RESULTS HERE
Yesterday i decided to put the techbench at OcUK through its paces and bench some graphics cards.
This is designed to give OcUK customers a simple to read breakdown of how a card performs in a standardised rig.
The test hardware used was a generic setup that a lot of customers tend to use.
i7 920 @ 4GHz
Asus P6T Deluxe [1303 BIOS]
Corsair Dominator 1600MHz DDR3 Triple Channel Kit
Noctua 1366 CPU Cooler [2X Scythe Ultra Kaze 2000RPM fans]
WD 150GB Velociraptor
Corsair 1000W PSU
24" Hyundai Monitor
and
the graphics card being tested
The cards that I have got through so far include all of the top of the range models going down to mid/high end
all of the cards mentioned are the standard, vanilla, stock speed & reference cooler cards - so pre overclocked cards might perform better than my results
the overclocked results were gained by myself overclocking the cards using ATI Overdrive for the ATI and Rivatuner for the Nvidia cards
hopefully this will give anyone buying a card a good indication of a cards performance and a basis of comparison
there are a few new cards on the horizon that i will benchmark using the same methods and add them to the list & charts
other cards will be added as i get more time
Synthetic Benchmarks:
The first two tests give an indication of how cards perform. the second test - 3dmark vantage takes advantage of PhysX technology - which is only found on Nvidia cards
i decided to enable this option in the Nvidia drivers as it is a feature of the card that may appeal to customers
[please note that scores for nvidia cards without the use of physx will be included over time due to demand]
all these tests were carried out using the standard settings for both versions of 3dmark
Vantage benches now include results with and without PhysX
real world game benchmarks give a fairer indication of performance
the fc2 benchmark is very unbiased and favours neither brand of graphics card
the crysis benchmark is slightly tipped in nvidias favour - however, the ATI cards do put up quite a fight
1680*1050 Benchmarks
The settings for the crysis benchmark tool were taken from the OcUK forums' Crysis benchmark thread
Benchmark GPU - DX10, 1680*1050, No AA, Overall Quality - Very High
The settings for the FarCry2 benchmark tool were taken from the OcUK forums' FarCry2 benchmark thread
Playback (Demo Ranch) DX10, 1680*1050, No AA, Overall Quality - Ultra High, HDR + Bloom enabled, AI: on
1900*1200 Benchmarks
[coming soon]
hopefully this will give you a nice indication of how todays current graphics card market performs
Those benchies goes to show much the 295 is ridiculously overpriced.
On the other hand, my 4870 looks like an amateur boxer compared to some heavyweights.
I'm feeling the need to upgrade. :confused::(:p
4870X2 looks great still, despite all the myths people post about it! I just loaded up Crysis Warhead, definately looks and feels better with the recent drivers :)
This is however '1680*1050' and no AA, not a very good resolution when comparing 4870x2 with GTX 295.
it had to be standardised - not everyone has a 1900*1200+ monitor
i think they are both evenly matched across a range of applications
Include some overclocked GTX260-216 results if you want to be a fair comparision, unless you don't want users at OCUK you know the GTX260 is a greater overclocker.
And for god sake add some AA in Far Cry 2.
Thanks for the review OcUK.
I think that a Vantage graph with Physx turned off would be interesting though.
Nice one, although come COD benchies please :D
This should be made a sticky if it'll be updated on a regular basis.
Thanks for this.. However:
No AA?
Why would anyone with one of these cards play without AA? Obviously Crysis tends to get dogged down by AA but then again, that is just one of the many reasons to not use Crysis as a benchmarking tool.
4ghz i7 is a "generic setup that a lot of customers tend to use"?
I think a 4ghz i7 setup is perhaps a *little* more powerful than most people's systems. Even those who have overclocked i7 rigs will likely have them running a tad bit slower than 4ghz. Not to mention all the people on 3.2-3.6ghz Kentsfield and below.
I'm trying not to be overly-negative here but the reviewing methodology is rather questionable.
Nice idea and your results hold true since they were all done on the same rig but my question is why are there all so low?
I thought the i7 at 4ghz would have meant that your results would beat the pants of my rig however I get 17314 in 3dmark06 and 13861 in vantage and that's with my cpu at 3.4Ghz :confused:
Hell my far cry 2 result was 70.15 fps as well.
Just wondering why yours are so low, not knocking the results as they are all releative to each other.
You've overclocked your GPU - a lot of these are done at stock.
Granted and I had noticed that but I would have thought it wouldn;t make the huge difference?
For example, I have an older generation cpu at 3.4 vs an i7 at 4Ghz and my overclocked gpu gives me a 18 fps boost in far cry 2 (over 30%???)
My cryis score is halfway between a stock GTX285 and a GTX295.
I'll run a benchie or two later at stock but you must admit it looks wrong????
That does seem a little high but perhaps you also have different settings in your graphics (e.g. set to 'performance' (etc) rather than 'high quality'). To be honest, Im not familiar with the clocks of the 260s and 280s - how good an overclock is the one on your card?
about a 20% overclock which is good but will not equate in a 20% or more gain in benchmarks.
Got to love it when someone makes an effort to contribute something to the forums and runs into comments like....
Why bother? :rolleyes:
Better to not bother at all than to post something misleading or incorrect as these numbers appear to be. Benchmarks from a company trying to sell the hardware in question should always be looked upon with suspicion.
The post was made, and feedback was given. This is how forums work.
