Software to Clone a Laptop into a Virtual Machine
24 Sep 2007
Hi All
After experiencing the major inconvenience of my laptop hard drive dying, I want to make sure that next time I am better prepared.
I want to have a solution where I can clone a given laptop, so that I can immediately restore the whole laptop again or have access to an identical copy of the laptop on another machine as necessary.
What is the best software to do the initial clone?
What's the easiest way to make sure your restore works, and to make sure the clone is always accessible on another machine? I could buy some virtual machine technology if necessary. Would VM Ware be worthwhile?
Thanks for all comments.
Rgds
VMWare would be the way forward ... also, they do a product called VMWare Convertor which converts a physical computer/laptop to a virtual machine, which you can then run in VMWare workstation or player etc ... it's really quick and i've never had it fail etc ... works wonders!!!
Second vote for Vmware converter, which is a free product I believe.
VMware Workstation isnt free, but you should be able to download and use VMware Player easy enough.
Neo
Whether or not you're going to image the hdd for use in a VM, don't forget to do a normal image (eg Acronis) so that you can physically restore the image to a new hdd once it's installed. I'm presuming you would want to use the physical laptop again rather than stick to VM forever once it fails? :)
Just as a side question - would the converter work and create images that would work across the VMWare range (thinking specifically ESXi)
Cheers
OK great.
Once you have the laptop working in a virtual machine on your desktop, can you then just copy a file out of the laptop virtual machine onto the desktop hard drive?
Thanks
Cheers
As long as there not outdated they will work. You may need to use the converter again to load them into ESXi, i've never had any luck with other methods.
OK great.
Thanks
To do it that way you would need to share the files/folders between the VM and host machine, the easier way would be to use the vmware-mount.exe tool and mount the vmdk as a hard drive on your local machine.
see
http://www.vmwarez.com/2005/11/new-vmdk-mount-utility.html
Another question. I see the Converter has created the following folders and files:
computername.vmdk.lck folder
computername.vmdk
computername.vmx
So, if I want to have access to the above VM on another of my computers, is it just a case of copying this set of files across?
Thanks
Vmware Server Query
Hi NeoNemesis
Sorry for hijacking this post....
I have a query, in your reply you mention vmware server. Is this free to use or is it only free to try i.e. 30 days? I've tried using using Microsofts Virtual PC and also Virtual Box, Virtual Box seems a bit better to use out of the two. I've seen vmware mentioned many times and was under the impression that it was really expensive. Am I missing something really obvious (highly likely)...
If this is free, also what makes it so much better than the other 2 I've mentioned??????
I vote for True Acronis Echo Workstation + Universal restore. You can convert .tib files to VirtualPC/Vmware images and vice versa!!! Brilliant if you wanna customise your workstation in a virtual machine before hand.
Universal restore strips the drivers, changes the SID and even changes the HAL!!!! So it can be restored on all workstations ;).
Downside it costs alittle but for what it does it's nothing for technicians and enthusiasts..
Hi NeoNemesis
VMware are the biggest player in the enterprise virtualisation space, so they have some extremely pricy enterprise virtualisation solutions = VMware ESX.
VMware workstation is the PC based version of their enterprise software, it carries a licence cost - cant remember how much now, but it is the best desktop virtualisation product out there.
I was under the impression that VMware server was free - it certainly used to be, as it is a scaled down version of Workstation.
I have used all of the Vmware product-set as well as MS Virtual PC. The Vmware products are vastly superior in terms of features and usability.
But when it comes down to it, MS VPC does the job.
Hope that answers for you!
I was under the impression you couldnt convert back from a vm image though? Which makes vmware kind of pointless in this situation. Your best bet for what you want is some sort of disk cloning software such as ghost, acronis etc.
All I care about is business continuity, i.e. once my laptop drive fails I don't want to have to spend the next few days reinstalling everything and faffing around. If I have to always work in a virtual machine, that would be fine, as long as I can keep a backup copy of that virtual machine somewhere and can instantly restore it to another computer if needs be. Is that possible, thoughts anyone?
Rgds
You can convert back from virtual to physical, however I have never found any free software that allows you to do it.
The best product for all of the suggestions mentioned is Platespin Powerconvert.
