Windows 7 7068 First impressions
PB seems to have problems with Windows 7 as it's still a beta Evenbalance aren't supporting it. Is that likely to change once it becomes a RC opposed to Beta?
well i got in touch with them over it and they said no support till it was a final release to the public :mad:
Just installed as my main OS, nice and snappy, hope it stays this way :D
Anyone know how to get IE8 to open all new tabs with homepage? Been on FF so long I can't figure it out?
EDIT: Ignore me found it :)
Probly not supposed to ask here.. so I'll say 'Email in Trust'.. but where can I get 7068 from??.. I've searched and can't seem to find it!... :)
Has anyone else noticed that if you drag a window to the top of the screen and release it'll maximise (it'll show a little blob and an outline of it maximising before you release the mouse button)? It also does this if you drag it to the left or right of the screen however it'll just maximise to half the screens width depending on which side. A bit hard to explain and I'm unsire if this has been noticed before or not; but it's new to me!
my bios battery died and when the clocks reset it would not log on and came up as counterfeit
Did you try setting the clock back to normal? I'm pretty sure Vista behaves the same way if it's not activated and is still in it's countdown period.
using 64bit version of nod32 all fine for me!
Hmm couldn't get the 64bit version last night which is why I asked..?
Will have another bash later.........
EDIT: Anyone know how to get shoot of that annoying water mark on the bottom right? The old reg trick didn't work for me?
Hmm, not sure if it was a one off but my speakers started hissing and popping randomly and music was unbearable. I had to restart in the end.
Had this with my audigy 2 on bulid 7057, Works fine on build 7068 though, try some different drivers. Either from windows update or creative site
x64 W7 7057 X-Fi beta W7 drivers
Anyone else getting missing audio when in the car on GTA IV with the above setup? I can't hear Niko talk and I can't hear any mobile phone conversations in the car. All other scenarios, the audio is fine and it didn't happen when I was on Vista.
