Graphics Card Temps
20 Oct 2002
Oxfordshire / Bucks
Hi all
for all the air cooled systems, what graphics car temps at idle do you get?
I get 51 C (using speed fan) which i thought was rather high, its a inno 3D 8800GT O/C
1st 9800GTX+ with the good heatsink idles at 50, load on 65.
2nd 9800GTX+ with the stupid heatsink idles at 46, load 72.
So I'd say your temps are ok.
It also depends on how good the airflow is in your case.
XFX 4870 here, idles at around 45c, around 70c under load for over an hour, auto set the fan to a constant 30%, the XFX fan is amazingly good if you crank it up, but the noise is unbelievable.
