Hunter wheel alignment prices
18 Oct 2002
Birmingham
£100 inc VAT for check and adjustment at Wheels in Motion. Highly regarded for setting the alignment on MX5s on the owners club and other forums which is why I went there.
29 Sep 2005
I see, so after fitting new larger alloys to a car (in a typical Booner fashion!).... would this be advised to reduce uneven tyre wear?
OP
18 Oct 2002
Nr Colchester, Essex
Thanks for the info people.
I am toying with Lowering springs and renewing all my suspension bushes, as well as getting my larger wheels back on. Doesn't work out cheap mind!
I need the tracking doing anyway as I am getting slightly uneven tyre wear.
Wheels in motion is a fair way from me, not sure it's worth it just for an alignment.
2 Jun 2003
See: http://www.alignmycar.co.uk/ for the nearest place that has a Hunter (there is also a 5% discount voucher on there).
22 Jul 2006
So adding 18" alloys & a new suspension setup to a mondeo ST24, it could be advisable to get this done?
29 Jul 2004
I'd advise you to do it anyway, since the settings can be out from optimal even from the factory.
Best money you can spend on a nice car is a geometry check and adjustment!
29 Jul 2004
Alignment is one of the most important things to get checked on your car! Especailly rear wheel drive cars, tracking wont fix your uneven tyre wear at all if your camber/toe/castor are all out, which if your car is over 3 years old it probably is by now, in fact tracking is useless compared to a four wheel geometry checkup :p
Get it done at a reputable place, will make your car drive like its brand new.
19 Oct 2005
Kernow
When i was getting some valves fitted at a garage (one valve was leaking!) i noticed that they had a hunter machine there.
May have to go and have this done. Will enquire about price.
16 Aug 2004
New Jersey, USA
Posted this before but:
This was after the 'tracking' was done by some tyre place - yet every measurement was out! Made a massive difference to the way it drove - no more uneven tyre wear and the car drives better as a result.
