- 8 Jan 2007
- Northallerton,North Yorks
I play about 6 hours a night and we played like 1 week ago, a lot can changeYou turtled a lot against me as I was punishing you for it.
I play about 6 hours a night and we played like 1 week ago, a lot can change![]()
We'll have to play again to see if you've improved much.I hardly play turtle Blanka, I'm the one that's always on the offence, I seem to be turtling cos there is nothing I can do when you are sat on downback charge. You throw out booms all day long and punish nearly every move with flashkick and I can't even slide under booms because you block with being on downback charge straight away. Any time I knocked you down I was instantly moving in for crossups and wakeup game shenanigans. Ask void how much I rushed down his Sagat, Guile is just more annoying.
Madcatz SE (with Sanwa components): £70 (£100)
The TE is not worth it (as the modded SE is identical in performance for £50 less) and neither is the fightpad.
I will be totally honest mate, some games I did play the zone sonic boom game. But I knew its cheesy since a lot of players complain of Akuma players just spamming fireballs so I just know how you feel. So I didnt play zone for many of my games to make the games more interesting.
Had I decided to really play tournament style, I would have made sure you dont get a chance to get into close quarters combat with me by spamming sonics and being ultra defensive, but thats just plain plain boring. Albeit if I keep doing it you will eventually have to find away to counter such a defensive tactic. It has to be said that Guile is probably one of the most defensive players in the game so its no brainer to play him as such really.
As to the hop/ultra, I honestly think that you didnt connect it, then again I may have been hallucinating from lack of sleep![]()
I play a hybrid Blanka and would like a Ryu sparring partner![]()
Still think his sweep is rediculously unpunishable, I was taking mad damage cos everytime you sonic boomed and came in to sweep I was trying different attacks to punish and only upball inbetween the first and second kick seems to work and that a tight window and only available if I have down charge.
After a couple of games earlier I have realised how bad I have become at this game after having a break!
live - oldlady187
Any fellow poor players feel free to add!
I thought I was your Ryu sparring partner! I've only been playing with you for a few weeks and you've gone and dumped me already.![]()
the sanwa parts cost me £47![]()
guiles roundhouse sweep is regarded as a terrible move because its very high punishable.
im certain you will find something that punishes it, even a roundhouse sweep of your own after the first blocked hit should connect... i'd have to test it out but it sounds like it should work (i think ryu/ken can do this). if all else fails you should be able to get free FA out of it, i dont know about crumple but definitely a free hit
edit- after 5 mins testing, cr.hk doesnt work, but cr.lp, s.lp, cr.mk, s.mk and possible others (i didnt test everything)... i dunno if they are good combo starters for blanka. after blocking the first hit it also puts you it good range for cross ups na doyu can jump after blocking the first. you have more options for punishment if you are sitting on charge. FA is also very easy
I never see you online any more![]()
I was in a game with Lucifer before that which is why I didn't join before (I feel I should mention that I managed to get a perfect round against his Balrog* that session
). I might be on tonight, but more than likely I will be on tomorrow night or at some point on the Saturday.
Maybe it's just input lag in online matches, we were up and down between 3 and 4 bar connection but I did try a lot of options inbetween and always seemed to eat the second sweep, with the exception of upball.
cr.lp, s.lp, cr.mk, s.mk don't work at the range Cav uses sweep, he's usually at max or slightly longer than max range, first sweep misses, baited an attack and the second sweep hits for knockdown.
All constructive discussion and arguments
