MoNsTa
11 Jul 2003
Telford//west mids
New build log for my new case got the name from the rad that will be installed into it.
Case--Lian li v2000
Powdercoated white
Inside done in satin black
Lower rad cuts to both panels
2 X 140mm fan cuts in the roof with custom grill
Window panel cut
Mesh for the rad and window cuts AC Ryan black hexx
Hardware
Cpu--i7 920 (Air cooled for now)
Motherboard-- Asus Rampage Extreme II
Memory--- Corsair PC3-12800C8 1600MHz (3x1GB) Triple Channel DDR3 (Corsair memory cooler fan blades painted white)
Videocard--EVGA 285 ***
Psu---Be Quiet! Dark Power Pro 750watt
Hard drive---Western Digital VelociRaptor 150GB
DVD Writer Painted satin black
Case Extras
Lian Li EX-33 Painted satin black
Lamptron FAN-ATIC Baybus (Painted white to match case)
Lian Li stealth DVD drive
Lian Li mesh bay covers
Black Lian Li wheels
Bitspower X-Station 2 power extension block
Watercooling parts
Rad--Feser Xchanger Black Monsta Extreme Radiator 420/360
Fans--6 X Yate Loon 140mm
Fittings--10 X Bitspower 3/8in. Compression Fittings for 5/8in.(For cpu,gpu,n/b,s/b and mosfet blocks)
4 X Feser 3/8" ID - 5/8" OD Compression Fitting (Rad and res)
10 x Bitspower 45 rotorys
Hose--10 X (XSPC)3/8" ID - 5/8" OD White hose
Pump--Laing DDC1+ Ultra 18W (MCP355) with Laing DDC Top/w Reservoir (XSPC)
Laing DDC 4 Point Anti-Vibration Damping Kit
Cpu waterblock--Watercool HeatKiller CPU LGA1366 Rev. 3.0 LT
Mosfets-- 2X EK
Northbridge/southbridge--Koolance MB-ASR2E & DRAM Cooler for MB-ASR2E (Both tops painted satin black)
Now for a few piccys i will update when i can but work has me very busy at the moment.
Did a test fit and the monsta fits just :) belive it or not the rivets on the top panel and just hitting the psu so i`ll have to drill them out and fit countersunk ones
And one with a 140mm yate loon on
Not sure as ive got a few more small bits to get to finish it off.
@Monkey Puzzle not even had to time to fire them up yet as im working on the case,some threads have been blocked up from the powdercoating so i have to sort this out.
Looking good clone still got your old quad sitting here still waiting on other parts to come so I can start the new build
Very nice :)
I painted my case white quite a while ago, but did it myself with car paint.. Now I wish I'd forked out for powder coating!
Looking forward to seeing the white hosing :)
Psu problem solved :)
Turned the plate around and redrilled the holes now fan at the bottom,just got to cover up the bare bit with black paint.
really liking the color scheme of the case, looks very modern!
cant wait to see the finished product, good luck with it
Looking really. Just one question about where you got the grill from. Not sure about the rules as OCers don't stock any 140 sized ones.
havent jaw dropped over a case since i bought my coolermaster black widow way back when (which i still have) but seriously that is one gorgeous case.....could white be this seasons black?
