 - 23 Aug 2008
Before going for the big runs I was tempted to see how stock volt's will do
, although 1.41 vcore is rather on the high side.Off Topic:
It has been noted by a few forum members that Intel® Core™2 processors with a low VID run hotter than a chip with a high VID.
It's not something I've experienced myself so don't know
You would think a lower vCore would produce lower temps but perhaps that is why Intel® assign the VID that way . . . . because certain silicon runs a lot hotter at a given frequency then other silicon?
Good work, the CoH numbers concern me though as every single test comes in with max fps of 76/77fps - maybe vsync is enabled?
Can you post your bios settings on that board please.I replaced my E2180 at 3GHz with an E5200 and am currently sitting at 3.6GHz for over an hour on Orthos (12.5 x 288fsb, vcore up to 1.3v) - did'nt think it would get there on a Gigabyte 965P-DS3 mobo, and the temps have hit 60' once, but that aside I am very impresssed by it. Plays Arma on high settings with fps in the late 50s compared to medium settings and fps averaging in the 40s.
For tight fisted, ahem, budget conscious types like me it is a good move from an E2x00.
Happy easter all !
cjph
Nope. I hardly ever use vsync. I had just presumed that it had a fps cap. It won't go past 76/77 fps with my 4870 either.
I seem to be very lucky so far with E5200's, suprised this one managed 3.85 considering the not so great VID.Had to stick the chip under Scythe Mine Rev B to keep temps down though...
