13 Apr 2009 at 19:36 #61 SBD SBD Associate Joined 24 Oct 2007 Posts 772 Location Leicester/Norwich u might find you can go higher now also loosen the ram timings then u should get even higher cpu speeds wish i could play with my pc
13 Apr 2009 at 19:38 #62 paradisiac paradisiac Soldato OP Joined 22 Mar 2009 Posts 7,754 Location Cornwall will have more of a play later, will see how it goes on the 3GHz
13 Apr 2009 at 20:42 #63 paradisiac paradisiac Soldato OP Joined 22 Mar 2009 Posts 7,754 Location Cornwall do you think with the ram being clocked at 667 it might take all 4 sticks now or do you think its prob the fact they are different makes?
13 Apr 2009 at 20:47 #64 SBD SBD Associate Joined 24 Oct 2007 Posts 772 Location Leicester/Norwich Well you can try it but i think because they are made by different manufactures they will still cause problems give it a try i you want tho
13 Apr 2009 at 20:48 #65 RJC RJC Don Joined 29 May 2005 Posts 29,104 Location Kent Also increase the Northbridge (MCH) voltage, it may help.
13 Apr 2009 at 21:21 #66 paradisiac paradisiac Soldato OP Joined 22 Mar 2009 Posts 7,754 Location Cornwall RJC said: Also increase the Northbridge (MCH) voltage, it may help. Click to expand... im not confident on whats a safe voltage to go to which is why i havent played with them, could probs oc it quite a bit more if i knew what was safe.
13 Apr 2009 at 21:29 #67 SBD SBD Associate Joined 24 Oct 2007 Posts 772 Location Leicester/Norwich paradisiac said: im not confident on whats a safe voltage to go to which is why i havent played with them, could probs oc it quite a bit more if i knew what was safe. Click to expand... Just up it a little that will always be safe just dont go mad
13 Apr 2009 at 21:37 #68 RJC RJC Don Joined 29 May 2005 Posts 29,104 Location Kent Increase by .1 to .5v in the bios and see how yoy get on, you might need to higher. My Abit IP35 Pro needed 1.4v to run.
13 Apr 2009 at 21:47 #69 paradisiac paradisiac Soldato OP Joined 22 Mar 2009 Posts 7,754 Location Cornwall might give that a go tomorrow, if not will look into selling my ram and getting 2 matched pairs, although not sure if i will ever need 8gb
14 Apr 2009 at 18:09 #70 paradisiac paradisiac Soldato OP Joined 22 Mar 2009 Posts 7,754 Location Cornwall well upping the volts a bit its now stable at 3.25GHz but still cant get all 4 sticks to work
